we got the stove from TSC about a year ago and finally installed it as I burned wood before. ran the initial sequence and all ok.. then during running the dry run procedure it does not complete and says there is a draft issue?? and the exhaust fan just starts, then stops right away and repeats. Door closed all my connections on the exhaust are good and sealed with sealant. I DONT have a OAK and draw from the room, 1100 sq ft so no neg pressure issues as my last stove pulled air from the room. I dont know what to check or do to tryand solve this issue?? I guess I also dont understand what the stove is doing? creating a vaccum pressure in the fire box and thus it leaks air or what??
while its trying to do this..if i OPEN the door the exhaust fans stays running???
I would GREATLY appreciate any advise or help of what to check to solve this issue!!
Oh Ive also seen many people ask about vents and piping and that. I have it at a 45 degree angle in room so I have a 45 elbow 2 1' pipes through the thimble to the tee. then 5' or so of rise of 3" pipe as called for in the manual. Instructions said outside should be 3' but my wife wanted me to go a little higher....could this be the issue as I see many seem to point to the venting in some way.
! Fan speeds have not been messed with since in auto mode for the dry test the manual calls for..... I will check regardless and see,.
