I've done two break-in burns on my Fireview now, and I went up top to raise the liner a bit. (The pipe going to my tee was angled down slightly toward the back, so I had to correct it.)
Anyway, the inside of my stainless flex pipe had visible, sticky, blackish resin. Not opaque by any means, but there. Now, of course, the break-in burns aren't supposed to get very, and I did make the mistake of using too much wood on the first burn, so even after I shut the air control down, the remaining two splits continued to smolder for hours.
Is it normal to get some creosote from the low-level break-in fires? Did I cause more creosote because of the extended smoldering? Is this anything to worry about, or will the normal burning to follow clean the pipe out pretty well?
