Hi there, I've been trying to figure out if this is a solution to my problem. First I have a central boiler 5036 which has been keeping up with heating my 1600 sqft house fine. I've built a 2500 sqft 14 ft high polebarn with radiant heat floors and my burn times don't last as long. I'm not surprised by this but thought I wouldn't burn thru a full box in 6 hrs or so. So can I add the Stiebel Eltron SBB 600 plus to the system to basically create more water storge. The tank has 162 gallon capacity which would almost double what the stove currently has. Also could I run the floor loops thru the 2 heat exchangers ( closed loop) ,upper loop is rated for 182000 btu/hr and the lower 242000 btu/hr. Would that pull enough heat if I just run the boiler water into the tank? I run my cb at 170 to 180 water temp. Thank you.
