I have a 1500 sq ft steel building workshop. Its well insulated and has three garage doors that are insulated. I have two 240 volt baseboard heaters on each end of the shop. I do various projects out of my shop and that will only continue as I get older. The heaters work well but take many hrs to really heat it up much and were installed just to maintain a low temp to keep the boat and other toys from freezing. I heat with would and have a jotul 450 and an outdoor wood boiler. I live on 25 acres at which 16 is wooded. I have access to tons of wood. I want to place a freestanding stove or pedatal type stove in my shop. My question is do I have to use the expensive double walled pipe. I would have several stack placement options. I could go straight out the roof. I could go out a window and up the side of the shop. Well I basically have three sensible options. One is less invasive without having to cut a hole in my roof. One other option is to go up about 13 ft and out the side of the building then up the side of the garage. I have read that double walled pipe is needed for going through the window or wall and up along the shed. My big question is it mandatory for inside the shop. What are the suggestions. I have called my insurance agent about this as well. They said just follow protocols for home installation so coverage isnt voided.
