Stove location for ranch home
Red44
1
Connecticut
I am about to purchase my first pellet stove and am looking for advice as to the best location for it. I have 2 options for locations (rough sketch below).
For reference, this is a 1600 square foot single story ranch in Connecticut. My goal is to use the stove as my primary heat source for at least the living room, kitchen/dining area, and 4 season sunroom and supplemental heat for the bedrooms. It would be great if it would provide the majority of the heating for the bedrooms, but if it can’t that’s not a deal breaker.
The bedrooms are on a separate zone for our existing system (hydronic baseboard heaters). For heat distribution, my plan is to either run our central air conditioner on fan only mode or run small fans to send cool air down the hallway toward the kitchen and warm air down toward the bedrooms.
Option 1 is in the corner of the dining area. This location seems like the best bet to get heat to the bedrooms, but I’m concerned that the kitchen/dining area will overheat too quickly before enough heat is distributed to the rest of the house. The sunroom is south facing and gets a ton of sun, which helps keep the kitchen warm. Even in the winter on a day that’s only partly sunny, the sunroom will easily get up to 70-75 degrees, and it breaks 80 in full sun. I’m concerned that I’d be left with either a lot of cold rooms or an unbearably hot kitchen if I leave the stove on long enough to get decent heat to the rest of the house.
Option 2 is in the corner of the living room. There is a wall separating the kitchen/dining area from the living room, but there is a pass through window that takes up about half the length of the wall (marked by the vertical lines in the sketch), so plenty of air moves between those rooms. My concern with this location is that it would be more difficult to get much heat down to the bedrooms. I’m leaning toward this location because I can live with using the existing heat for our bedrooms, but it would be great to avoid that if possible.
[Hearth.com] Stove location for ranch home
When I had a corner install in my living room, the heat got trapped for sure. It was really noisy with all the fans I had to run to circulate the warmth - and I only have a 960 sq/ft house. I had to have the corner install because the Hastings was too big to observe clearances to walls, while also having the exhaust where it needed to be for clearances of windows.
Since you have a good size opening in that wall to the kitchen from the living room, the heat would not be trapped as badly, and some should get to that hallway to the front entrance (I assume that is where that leads). But getting down the main hallway would be an issue. That corner kitchen install is even worse since it doesn't even remotely face the way you need the air to move. If it must be between those two orientations, the living room would be the best (especially since the sunroom helps heat the kitchen).
Is there the possibility of turning the stove in the kitchen to face the distribution blower down the hall? That is how I set up my P43 when I replaced the Hastings (P43 is not as wide, so had clearances I needed), and it works great. I don't have to use any auxiliary fans at all. I included the layout of my house to show what I'm saying.
Option 1 will be your best but your going to need some small fans to move the heat around especially something to sick it into the living room. I use a ceiling fan in the main room and then in the back i have a small wall mounted fan mounted up high and angled down to pull the heat from the ceiling down and create some circulation.. works well if my kid would ever leave the bedroom door open..LOL
I have two Harman stoves, one I bought new, the P68 in 2008 and a used one, the P38 in 2012. We have a 2300 sq ft "L" shaped ranch house. Like a lot houses, especially "L" shaped ranches, there was no ideal spot to place the stove. I had it installed in the "L" part of the house in a large living room. For 2/3 of the house the 68 did a good job, the remaining 1/3, OK but not toasty. Of course that part included the kitchen and the den. Needn't say anymore.
We have a zoned forced hot water system that we used to make it better. But didn't like the idea of paying for oil. But one day a good friend of mine asked if I wanted to buy his P38 and he said I'll throw in a generator also, $500. !!! I'll be right over. I knew he hated doing the pellet thing. I installed it in the other end of the house. Now the whole house is toasty. No more using oil, minimal complaints for me.
It's hard getting pellet stoves balanced, The spot where I always sit on the couch is close to the 38 pellet stove. Guaranteed right after supper, I fall asleep for a good 1/2 hour......but atleast I'm warm. :)
Tom
