I have an old wood burning stove that I'd like to disassemble, powdercoat, reassemble, and install.
It has an 8" outlet. I plan to use 8" damper at base, and run 8" stove pipe to about 24" below the ceiling.
I have a 10" insulated thru-ceiling outlet to outside above roof. Double wall to 24" below ceiling. An 8"-10" increaser/adapter will be attached below it. Also, I'm looking for the 3" gold balls that go on the top surface, front corners, please post if available.
Will opening the last section at top 2" larger from 8" to 10" be OK for flow?
![[Hearth.com] STOVE PIPE DIAMETER [Hearth.com] STOVE PIPE DIAMETER](https://www.hearth.com/talk/data/attachments/293/293423-52d783036abe273e9749b90deed61cae.jpg?hash=Qnjh4E_qiJ)
