I have an old VC Resolute I. Last night I loaded the stove up and was waiting for about 1/2 hour to get it ready for the overnight burn. As I was waiting, the air intake flap began to flap wildly and the stove was puffing smoke. It seemed odd so I opened up the air intake quite a bit more to see if I could get a better draft going. When I did this the air began to whoosh on and off quite loudly. Again it seemed as if something was wrong with the draft so I decided to open the damper. When I did this the fire in the stove picked up and it seemed as if I had fixed the problem until I took a look at the T in the pipe directly behind the stove. The T and the stainless flex pipe going up into the chimney were glowing bright red. I quickly shutdown the air intake, the secondary burn air inlet, and the damper. Stove Gridle temps were about 450 at this point. It took about 5 minutes for the pipe to stop glowing. I left the stove this way overnight and the next day as I was too nervous to start it back up.
1. Was the glowing red pipe caused by a chimney fire? What should I do to avoid this? Is the stove safe to continue to use?
2. I left the stove completely shutdown all night and the next day. Even though it was completly shutdown the griddle temps stayed at about about 300 for 16 hours. Where was the air coming from to feed the fire? I assumed if I closed the stove completely down it put out the fire. Do I need to worry about a leaky stove?
Thanks for any advice,
Aaron
Aaron
Glowing red!
