Hello all, me again, so I am trying to make sure I cover all the bases as I replace my wood stove and upgrade pipe and thimble. My question is, is there a rule of thumb as to how long your vertical run out of the stove should be in relation to the horizontal run into the chimney? My previous stove had a 14” vertical, 90 degree elbow, and then 30” horizontal into chimney. Previous owner mentioned draft issues( which could have come from a number of other things). The stove I just removed from another house had 22” vertical, 90 elbow, and then approx 46” horizontal into exterior pipe. I can only assume that it worked for them. I am contemplating cutting a new flue hole higher up in my chimney for my new install if it is rational. I could make new hole 2 feet higher and still retain proper ceiling distance. Boring an 8” hole through brick chimney and clay liner will be no easy task but I am willing to do it if it may help with draft. Can’t find any real guidelines on the web. Thanks in advance for any insight!
![[Hearth.com] Stove pipe vertical to horizontal ratio? [Hearth.com] Stove pipe vertical to horizontal ratio?](https://www.hearth.com/talk/data/attachments/295/295888-319fa15859816ef89086427c84d53fc6.jpg?hash=9GJX5rhMrn)
![[Hearth.com] Stove pipe vertical to horizontal ratio? [Hearth.com] Stove pipe vertical to horizontal ratio?](https://www.hearth.com/talk/data/attachments/295/295889-75fe983c5c9e027df781f0e0f69176c9.jpg?hash=oVM4gc_qqJ)
![[Hearth.com] Stove pipe vertical to horizontal ratio? [Hearth.com] Stove pipe vertical to horizontal ratio?](https://www.hearth.com/talk/data/attachments/295/295893-a1144676baa69921afc0bd8058953765.jpg?hash=w_QUspB7rW)
![[Hearth.com] Stove pipe vertical to horizontal ratio? [Hearth.com] Stove pipe vertical to horizontal ratio?](https://www.hearth.com/talk/data/attachments/295/295894-42644d8a850bfbc39079aa65c2e83339.jpg?hash=lkPX1wo5E_)
![[Hearth.com] Stove pipe vertical to horizontal ratio? [Hearth.com] Stove pipe vertical to horizontal ratio?](https://www.hearth.com/talk/data/attachments/295/295895-3b0da1c0ae1cf5eb422319d7c2023ed5.jpg?hash=1oKTzupbmP)
