GreetingsI have an approx. 2400 sq. ft. 2-story farm house (9 foot ceiling on 1st level) that is 100 years old. I am considering purchasing the PE Summit Classic to reduce my insane propane bills (hot water radiators). I believe I have a great location for this wood burner (next to stairs in central part of house with chimney running on back wall - see picture and measurements below). The Summit has fairly tight clearances too so I am hoping to set this up as tight as permissible (also in the running where Cape Cod and Liberty but I think the Summit is better for clearances).
I could use some advice on placement. The challenge for placement is the A/C air return (and A/C vent location). I’m probably going to have to move one or more floor holes.
I was thinking of a corner installation would be awesome here but the installer recommended I install it parallel to the back wall, centering it between the corner and the inside edge of the door woodwork. I think the installer preferred the stove position parallel to the wall so that the pipe coming out of the stove wouldn’t have to twist so far over to get to the chimney (see picture for chimney location), etc. He may have been concerned about too much heat just going up the stairs too with a corner installation (my speculation).
Anyway…. Just looking for ideas and suggestions as far as what would look right and what makes sense for this space. If I should use a ‘cookie cutter’ hearth platform, Which size would make sense? vs. If I should build a custom hearth to try and keep the A/C return exposed there (I’m thinking that having the A/C return grill there would be great for distributing heat with my central A/C fan, but maybe it would look strange and/or maybe there just isn’t room)
If I went with stove placement parallel to the back wall, I think I could place the hearth in front of the little A/C output Vent (unless that would look strange having the hearth in front of that register as opposed to starting at the back wall…. maybe I’d even be able to miss the larger a/c return vent that way (building a custom hearth) I know you need room on the hearth for some tools and maybe even a small wood bundle too, so maybe I do need to move the a/c return. Sorry to ramble on…. so many thoughts with so little sense of what would look right or what would make sense for this space. Thanks in advance for your help.
![[Hearth.com] Stove Placement [Hearth.com] Stove Placement](https://www.hearth.com/talk/data/attachments/151/151919-1b05ff1ae4d960880cb1a99aa796c489.jpg?hash=o_3NyZ8YZV)
