Stove Temp Queston
touchthewindrider
85
NC
I'm a bit confused with all the Cat temp, stove top temp threads. Can someone clarify for me?
My stove has a CAT probe. Will it's temp be different from the stove top? Say, with a gauge sitting some where else on the stove, then right on top of the CAT?
Thanks! Stay warm.
Linkback for more info would help, here it is: https://www.hearth.com/talk/threads/2014-2015-vc-owners-thread.132919/page-2#post-1820020
Your picture is of the catalytic probe, you will see temps of upwards of 1500 degrees when the cat is running on high.
Since you have a cat prob you need to use it to go by running your stove, at around 500-600 you close the damper and go into cat mode, start cutting the air back slowly and your cat should idle at around 1300-1500 at peak burn then drift back down for you to repeat the process again at reload.
Woodstock has a good write up on operating a cat stove, most of it will still apply to your stove: (broken link removed to http://www.woodstove.com/images/editorial_support/PDFs/fvcatalyticman.pdf)
Thanks mellow!!! I appreciate the feedback.
