i have a vc resolute. I have my thermometer about 20 " up the double wall pipe. Is this ok or should I put it directly on the stove top?
Yes it is a probe dust
Whole different animal. I have my probe about 6" up but it's probably too close. That just happened to be a much more convenient spot for me.Yes it is a probe dust
I like to have both.
If creosote forms at about 250 degrees (smoke condensing), what would be a goal in temp for the flue gasses leaving the stove collar or a probe 16 inches up the pipe? (internal temps)A flue probe helps one track stove efficiency and avoid getting below creosote condensation temps. A stove top thermometer lets you know how the stove is doing. I like to have both.
Why is that? Is that because after the flame stage there is no more risk of creosote?That is hard to say. As you've noted, single wall pipe is going to cool down flue gases much quicker than double-wall. Also the length and path of the stove pipe run, outdoor chimney length exposure and outdoor temps are going to have an effect. And it depends on the stage of the fire. I like to keep the flue internal temp in the double-wall stove pipe reading at least 400F during the outgassing phase and don't really care about the temp during the coal stage. YMMV depending on the flue setup.
I've been getting that too sometimes. Mostly when I burn my less dense pine-like fir (it's not Douglas Fir, though). My guess is that the early coaling stage is still giving off some creosote products but the secondaries are cooling too much to burn it off. Not sure.Also, I notice that if I don't reopen my air intake a little during the coaling stage I sometimes get more soot on the glass.
Most people get a build-up within a few feet of the chimney cap or on the cap itself. That's where the gases are coolest and the chimney is coldest. Personally, I think if your cap is pristine you are probably either never using your stove or you are allowing too much hot air out of your stove. I'm sure some will disagree and I have no intention of climbing everyone's chimney to justify my point. I got the info form Santa and he should know.How would you be able to tell if/when the gasses got below 250 higher up the flue, like say 15 feet or more? Is there a factor or magic formula?
Thanks for that info. I am one of those people.Most people get a build-up within a few feet of the chimney cap or on the cap itself. That's where the gases are coolest and the chimney is coldest. Personally, I think if your cap is pristine you are probably either never using your stove or you are allowing too much hot air out of your stove. I'm sure some will disagree and I have no intention of climbing everyone's chimney to justify my point. I got the info form Santa and he should know.![]()
Thanks.I am wondering what can be done to prevent this?
