My EKO40 system has been running very well during the last 2 week extreme cold spell up here in Northern Michigan.
I have been re-splitting my firewood (into sticks) so that I do not experience the bridging that I experienced early on when I was using the larger wood.
Since I have been doing this I have experienced no bridging (finally
!) . On the down side, I have experienced shorter burn times.
I have been running my boiler at 50% fan power, 40% fan opening, 5 mm on primary, 4 turns on secondary and 195-185-195 temperature setting.
I actually start out at 9mm on the primaries (I made the modification so that I can adjust this setting "on the fly") and after an hour or so, when things are burning well and the boiler is nice and hot, turn this down to 5mm.
Thus, to extend the burn times and extract more heat from the wood, I was thinking about elongating the slot on the primary slides so that I can reduce my gap to less than 5mm (the way it comes from the factory the slide bottoms out on the end of the slot and thus does not allow it to go any less than 5mm).
My thought is that I can keep decreasing this gap until I start to put the fire in the upper chamber out.
Has anyone tried this with their EKO (or other brand) of gasifier?
I was hoping to get some feed back before I remove the 12 screws on the front cover and make this adjustment (I'm also going to drill and tap these 12 holes and put in some nice socket head cap screws-the screws that came with the boiler are starting to strip out).
Thanks,
NWM
!) . On the down side, I have experienced shorter burn times.I have been running my boiler at 50% fan power, 40% fan opening, 5 mm on primary, 4 turns on secondary and 195-185-195 temperature setting.
Thanks,
NWM
