I got this stove installed and I cant tell if it is a paint curing smell or smoke smell. I have a wood burning insert and it isn't the same as the smoke smell from it. The pellet stove is installed in the basement and it has the pipe adapter installed then the tee inside. There is 6 feet of pipe inside a 90 and then a 12" section and the cap outside. I also installed the outside air kit and i used furnace tape on all joints. I cant see smoke coming from any joint. Any suggestions ?? I burned the stove for a couple hrs the 1st night, then couple hrs the next night and couple yesterday. I assume the draft is ok because our power went out yesterday and the basement didn't fill with smoke
