Tall Chimney Performance Questions
davargo
2
CT
I have a center chimney colonial style home built around 1785 in CT. The original chimney was rebuilt around the year 1900 from the ground up, it is brick with 4 individual flues, all unlined. Total height from the first floor to the chimney cap is approximately 32 feet. When we moved into the house 4 years ago we purchased a new Vermont Castings Encore and had it "professionally" installed, along with a 6" round flexible stainless chimney liner. Turns out I'm not super thrilled with the install job and am questioning some of what they did. I don't have any desire to climb up on the roof so would be hiring somebody to perform any work up there. I am familiar with the challenges of operating this stove and am working through many improvements I have read about on this forum. My questions here are specifically about the chimney.
1) The liner they installed is uninsulated. While much of the chimney is inside the house, about 12 feet passes through the attic and about 4 feet is above the roof line. Should we have pushed to have an insulated liner installed? When I asked the installer they said it would not be necessary. The flue is pretty tight on the 6 inch liner, it had to be ovalized slightly to make it through the old damper plate in the fireplace. Maybe an insulated liner would not have fit... I see there is a vermiculite based product that you can dump down around the liner, is this worthwhile? I sweep the chimney from the bottom 2-3 times per season and gather maybe 1 gallon of crunchy black creosote each time. I don't think this is too bad considering the length of the chimney. But there is some glass-like "liquid" that is firmly stuck to the walls of the pipe and does not diminish with brushing, I believe this is from flue gas condensing on its upward journey.
2) Due to the dimensions of the fireplace, we are using the rear exit on the Encore. It runs about 12-18" horizontally, then goes into an elbow up to the liner. Debris that falls down the chimney collects in this elbow and on one occasion in our first winter with this stove caught fire when the damper was left open too long on a hot reload. I am much more diligent about cleaning this elbow now, about every month (we burn only on weekends generally). I am considering swapping this elbow for a tee that would allow the debris to gather out of the direct path of any wayward flames, would this help? I actually think we might be able to squeeze the stove into the fireplace and use the vertical exit, but connecting the liner and cleaning it would be next to impossible.
3) I'm considering purchasing a used Magnehelic pressure gauge to measure my draft at various conditions. I'm wondering if some of my challenges operating the stove in a safe and controlled manner are a result of a high draft in my chimney. In which case insulating would probably make my problems worse and exacerbate any leaks in my stove. Is it better just to leave the chimney alone and deal with the stove itself? We get an occasional backpuff but I have attributed that to the tempermental Encore stove and my battles to keep it from melting itself down...
Have you ever measures the fluegas temperature at the chimney exit, or 1 meter down the chimney?
Doing so, you can understand, if you have issues with condensing gases.
In Sweden using vermiculite granulat is standard when using a non insulated liner. We only use non insulated liners with vermiculite granulated.
I’m only answering part of your questions that I feel I have some knowledge in.
Should liner have been insulated?
-yes. A lot of installers do not and say it’s unnecessary. It’s helpful for draft but mostly for safety in the even of a chimney fire to protect home. The foil wrapped insulation would have been the thing to ( or to do, if you hade things redone).
Not sure of the wood you’re burning but needs to be dry (20% moisture or less when tester on fresh split wood). Wet wood can cause more buildup. The height of chimney may cause more buildup as well. The shiny hard stuff you’re seeing indicates the temp in that area is too cool.
Another issue to consider is how well the chimney was cleaned by the installer prior to install of the stainless liner. If you go the route of having it re-done, make sure that all the nooks and crannies of the chimney get cleaned out.
Yes the liner should be insulated. The damper frame should have been cut out to make room. You should have a tee at the bottom not an elbow that will allow somewhere for the dirt to go and make cleaning easier. And you are absolutely over drafting you need atleast 1 damper in that horizontal section
I have never been on my roof and don't plan to get up there ever, so measuring the fluegas temp at the chimney exit probably won't happen unless I hire someone else to do that.
I wasn't home when the liner was installed, but I don't think they did any cleaning. That being said, I have some pictures from our home inspection during the purchase and it looks very clean. There are some bends in the flue so I can't see more than a couple feet up from the bottom.
[Hearth.com] Tall Chimney Performance Questions
I'm not sure what you mean by having a damper in the horizontal section. The stove has a damper to redirect smoke through the catalyst. Do you mean I should have a second damper immediately after the stove? Are you referring to the butterfly style damper that would go inside the pipe?
There are lots of things you want addressed. Most concerning to me is the amount creosote.
Do you have a moisture meeter and test on a room temp fresh split face?
Second you have a temperamental stove.
3 rd with a controllable stove and dry wood you are almost certainly overdrafting.
My guess is this you have e wet wood that is only burning well because the draft is really high. The results in lower due gas’s temps and excessive build up in an uninsulated very tall liner.
First step is to confirm if your chimney meets code I’m guess it does not. 2” air gap from masonry to all combustibles for an interior chimney. Safe bet is it does not. you need an insulated liner. Then address the draft with a damper. Test MC of your wood. Evaluate if you want to keep using the current stove.
Reactions: bholler
Yes a key damper maybe 2 in the pipe to bring draft down to a reasonable level
