Will call Tarm next week but thought I'd toss this out here first.
I have a few questions:
1) 4 times so far this weekend the fan shuts off due to hitting the limit on flue gas temp but when the temp lowers the fan did not automatically turn it self back on. Hard to believe this is normal. Temp is adjustable but factory high set is 249 and that's where I have it set. Sometimes the flue gas can hit 350 and the fan keeps running. Personally I have no problem with a higher flue gas temp. I'm thinking bad sensor but realize it could also be a relay on the board. Thoughts?
2) When cooling down from the above I'm getting condensate leaking from the flue collar joint from the stove to the first section of pipe. I've got pitch in the pipe and the joints are not sealed. Total pipe length is less than 4 feet and has a barometric damper installed and dumps into a 8X8 clay liner. Chimney is internal to the house and about 35' tall. Wood is 18-23% MC measured on fresh splits.
Stove is in my basement workshop and the tanks are enclosed in a very tight well insulated room. I'm going to have to open the windows to work down there. It's 74 when its normally 60. Hopefully in the winter it's a bit cooler
