Hi I am building an overkill alcove for a wood stove that is replacing a fireplace and chimney in earthquake country (the building department would not allow a more normal design). I will be tiling the first five or six feet of the inside of the alcove and need convection walls so am framing them in steel. Some of the steel will be visible at the bottom of the walls and through a large vent at the top of the alcove, so I'd like to paint them (as well as the durock that won't get tiled). I will buy high heat paint but am worried about it on the framing which is, I believe, galvanized. So I am told that I need to use a water based primer for galvanized and those are not usually high heat. Any idea of how hot the inside of a convection wall will get or idea of what primer to use?
On a second note, I am thinking of angling the (side) convection walls akin to a Rumford design so that it will hopefully direct more heat out. Has anyone experimented with this?
Thanks
Rob
Thanks
Rob
