Are there any wood-burning metal firebox inserts that don't  produce more heat than the traditional old-style brick open fireplaces?
We are planning to get a wood burning fireplace built here and the builder suggested I look into fireplace inserts or as he put it 'metal boxes' as they are much cheaper to install. From my very limited understanding of these they seem to be designed, through the use of firebacks and convection chambers, to produce much more heat than a regular old fashioned brick open fireplace. Is this correct? I'm asking because we are wanting the fireplace more for the ambiance and as a decorative feature rather than a heater (though we still want a wood-burning one not one that burns gas or ethanol). Are there any fireplace insert designs that don't produce any more heat than a regular fireplace, or even produce less?
I know it's not the green thing to do but I'm after a fireplace where you can sit by a big bright fire without getting too hot. I know the ethanol ones are great and can do this but I also need to be able to burn things in the fire. I read that the traditional open fireplaces have a very low efficiency rating and that most of the heat goes straight up the chimney (which is actually what I'm after). I just wanted to check that there aren't any fireboxes that are also like this, because it sounds like this would be a far less expensive option.
Cheers.
PS. I live in Australia so my options regarding the fireboxes are probably more limited.
Cheers.
