Hi Folks,
We have been running our new insert for a few weeks now, and are extemely impressed. It's been below freezing temps overnight off and on, but the cold certainly hasn't hit yet.
No trouble with draft, smoke in house, or anything like that.
Great overnight burns of 9 hours ** (Not full heat, as fan is cycling in AM, but plenty of coals in AM.. No need for kinding, just throw in a few stciks, and off again)***
The "trouble" is that my girlfriend is worried as the temp gauge we have stuck (magnetic) to the front of the firebox, just above the edge of the door often shows temps , in the danger zone. It is really a chimney thermostat, made to stick on the stove pipe, about 18" up from the stove. Of course, the pipe is covered and the stovetop plate is actually a separate plate attached on top of the firebox.. - so, I figured the best palce to measye the temp was the side, or front of the firebox.
Last night, after loading up foir the night, and leaving the air on med-high for 20 minutes, to make sure that the wood was going well, before damping down, the thermomter (burn indicator) was fully in the red, reading about 750-=800 degrees. I do have a cheap digital temp reader, and after pointing it ayt the front / side of the firebox, the highest it measured was about 600. The top plate was about 450.
So, is my "burn indicator" magnetic thermostat reading higher because I am using it on the firebox, and not on the stovepipe? I really just wanted to use it for a quick glance "guideline" for checking the stove.
I do agree with her, that it "felt" like it was burning a bit too hot last night. However, as I only ran it for 20 minutes on med- high air, before shutting it down, is that not reasonable??
The burn indicator has a scale from 0-300 (cresosote) 300-550 (burn zone / comfortable) 600 - 800+ (overfire/ danger)
Setup:
- Pacific insert
- external chimney (not insulated) approx 19'
- Block off blate and sealed top cap.
Any advcie would be appreciated
Setup:
- Pacific insert
