Terracotta removal/relining risky?
Dodd10x
11
21131
I recently purchased a new house with two fireplaces on one two story chimney (so probably 30-35 foot). The chimney sweep/inspector says that the lining is failing and should be relined. Because the chimney has two flues I'm told an insulated stainless liner wouldn't fit without removing the terracotta.
Another chimney guy told me that's a dangerous operation, especially on two flues, and he's seen chimneys collapse when the chain hit some weak brick.
Is this something I need to worry about? Are there alternatives?
I'm planning on having a wood insert installed as well.
begreen
Mooderator
Staff member
Nov 18, 2005
100,838
South Puget Sound, WA
What is the ID of each clay liner? Did the chimney person discuss installing an oval, preinsulated liner like DuraLiner?
Dodd10x
11
21131
They didn't go into those specifics on the clay and I didn't know enough to ask. They showed me all the deteriorating spots on camera and talked about the tile size and such.
They did say it would be a preinsulated liner, and that's the reason for knocking out the terracotta. I think they said the opening was only about 7 inches in one direction currently.
This was in December though, when we first moved in, so I don't remember the details.
begreen
Mooderator
Staff member
Nov 18, 2005
100,838
Sounds like they may be 7 x 11 ID tiles. DuraLiner oval liner is made specifically to solve this issue. Or if the installer has a proper ovalizer they may choose to use that on a preinsulated flex liner.
bholler
Chimney sweep
Staff member
Jan 14, 2014
32,298
central pa
Are you relining for an open fireplace or for a stove? We break out liners all the time I have done hundreds and never had a chimney collapse. But if it's for a stove or insert I would just use an oval liner
Dodd10x
11
21131
I'd like to do a stove insert. An oval liner wasn't an option they proposed. That's the kind of information I was hoping to find out here! Thank you, I will look into those. I'm sure it would save me some cash over knocking all that tile out.
Dodd10x
11
21131
That's exactly what I was looking for! I'm going to have to look into an oval liner and ask some questions of the next people I have give me an estimate.
bholler
Chimney sweep
Staff member
Jan 14, 2014
32,298
central pa
Not much money saved no. But I prefer not breaking out in fireplaces if not absolutely nessecary
Reactions: moresnow
bholler
Chimney sweep
Staff member
Jan 14, 2014
32,298
central pa
I have no idea what Napoleon inserts are going for now
bholler
Chimney sweep
Staff member
Jan 14, 2014
32,298
central pa
4200 according to them. I'm not set on a particular make or model - that just happens to be the brand they use.
4800 is certainly on the high side for a liner and install
begreen
Mooderator
Staff member
Nov 18, 2005
100,838
That particular chimney place wants 9 grand for relining and sourcing/installing a Napoleon Oakdale........
Seems pretty darn high, even if this is a $3,500 insert. What other inserts have you considered?
Dodd10x
11
21131
Thanks for the confirmation. I have a couple more estimates I'm getting. I think I'd be happy with something like a Regency i2450, Drolet 1800 or Osburn 2000 also. Just depends on what is available. I don't mind them sticking out some since it's supposed to give more heat if power is lost. Smaller viewing area is probably the biggest downside I can think of for the Regency.
begreen
Mooderator
Staff member
Nov 18, 2005
100,838
Based on word from SBI, inventory is already committed. So if you find an insert that will work and is priced right. Go for it.
Reactions: EbS-P
Dodd10x
11
21131
Just had another chimney company out. They said the opening is 9x13 and I shouldn't have issues with installing a 6 inch insulated liner.
bholler
Chimney sweep
Staff member
Jan 14, 2014
32,298
central pa
That is doubtful. I have never seen one that an insulated liner would fit in
begreen
Mooderator
Staff member
Nov 18, 2005
100,838
lawn717
45
PA
I don’t wish to hijak this thread, but I have a question I believe applies.
My chimney has a 7x12” inside diameter. I wish to insert the Drolet 1800i (may be out of luck for the time being), but is the DuraLiner my best/only bet?
begreen
Mooderator
Staff member
Nov 18, 2005
100,838
Duraliner oval is a good option. Another is a preinsulated liner that is properly ovalized.
Reactions: lawn717
bholler
Chimney sweep
Staff member
Jan 14, 2014
32,298
central pa
Dura liner is a good option. But any liner can be ovalized to work as well
Reactions: lawn717
