The Ideal Steel in black
Note that I was estimating not stating the burntimes. My comparison was to the Cape Cod. Until will have some actual field results the burntimes are a guess at best. Also, I was being conservative in defining burn time as the period of meaningful heat, not to coals enough for a restart.
I think the intended purpose is about more than function. At least I hope so because if the focus is on performance then they failed with only a 10-12 hour burntime as BG quoted. Perhaps it would be wise to shift the emphasis to a low cost, basic, stove that performs almost as well as the other woodstock stoves?
Emphasis on low cost is not a bad idea. However, to say they failed with only 10 -12 hour burn times is ridiculous. Those burn times are ideal for most of us stove owners. Getting through the night with plenty of heat and a good hot bed of coals in the morning is the goal. And doing it with super low pollution and a nice fire show is even better. All in all, I think the early results for this stove are very impressive, especially at this price point. It may not win any beauty contests, but for a great many people, looks take a back seat to performance. And in simple black without the moose antlers, it doesn't look bad at all.
Reactions: mudr
I just went to the Blaze King site and took a look at their stoves. I don't know much about wood stoves- I am trying to learn- but the spec numbers looked impressive to my untrained eye. I am all about function over form. That being said, I do appreciate the aesthetic as well. I think the Blaze King stoves look fine! They look like wood stoves- which is what I expect a wood stove to look like- both on the web site and in the house. I think they are quite attractive.
Humor a newbie: do the Ideal Steel numbers compete with the Blaze King numbers so far?
Not even close, the BK specs KILL anything from woodstock as far as function. If function is your goal then you need to stick with BK for now. Woodstock has put out one new stove in the last year and now this IdealSteel is coming out so they may someday make a run at BK. Both companies make great stoves and you can believe the posted specs from their marketing. Really sit down and compare line for line each spec before you buy.
I owned a soapstone stove. Meh, the stone offers very little advantage in real life.
Not all blowers are noisy and not all stoves are in a location where noise matters. I think this may be an oversight on their part coming from soapstone stoves. A blower should be optional IMO. All homes are not created equally. Some stove locations benefit from a boost in convection.
You hit the nail right on the head when you said 'optional'. That way, everyone can be happy. :-)
If all you want is 10-12 hours of burntime, a basic stove, a cheap stove, one with a dependable reputation and low emissions then an NC-30 will do the job.
If a smoldering fire with less heat is your goal, than you can't beat BK. Also, remember that it takes an hour just to fill it up with wood. Lets be practical here: you know you are going to want to check your stove before you go to bed and when you wake up.....so what is the point of 35 hour smudge pot fires? And, if you take pride in the way your home looks, it's hard to beat the beauty of a Woodstock stove. If you're going to ban the stove to an unfinished basement, then you might as well go ugly with a BK.
This is getting a bit silly. You can fill up a Princess in the same time as a Progress or our T6. Yes, the BK can be turned down and run at a lower temp than our stove, but the inference that it is burning dirty is incorrect. It's anything but a smudge pot. FWIW, the newest BKs are not bad looking at all IMHO. In particular I like the lines of the Ashford.
Now let's get back on topic and stick to the Ideal Steel. This is not a discussion about pure soapstone stoves.
This is getting a bit silly. You can fill up a Princess in the same time as a Progress or our T6. Yes, the BK can be turned down and run at a lower temp than our stove, but the inference that it is burning dirty is incorrect. It is anything but a smudge pot. The newest BKs are not bad looking at all IMHO. In particular I like the lines of the Ashford.
I think they are ugly.......but to each his own.
If you are using the burn time definition of enough coals to easily relight, then I'd have to guess the Ideal Steel will push 20 hours or so. With that definition, my PH gets 16 hours "burn times" easily and the Ideal Steel is quite a bit bigger. Personally, I hate that definition because 90% of my heating season I need HEAT, not just coals.
Getting real, siginificant heat for 12 hours is my top priority when it comes to function. Probably many others too.
Reactions: Tenn Dave
I think the Steel will provide longer burns than 10-12 hours. I think with good hard wood, dialed in, you will get 15+ hours of heat for most people.
BrianK is going to do a long, slow burn with oak pallet scraps this weekend. The results should be interesting.
Do you think the Ideal Steel is a beauty?
Nope, I already said that several times on this thread. But I don't think it is ugly either. It is just not my style. (Although the one in simple black without all the add ons is starting to grow on me.) I like the looks of the Progress Hybrid - and I bought one.
That could be very possible, again I was just comparing it to the meaningful heat times of the Cape Cod. However, Highbeam brings up a good point. In order for it to be more than a curiosity the IS is going to have to have some distinguishing features. The price point is good but Drolet and Englander easily own the low-price, big stove market. Another win might be in efficiency. If the IS can out-heat a similar 3 cu ft stove that could be a plus. Another could be meeting stricter EPA regs, which might leave out some stoves. And there is customizability which may be attractive to a certain market segment. Some folks just want to have something unique.
When you start adding up all the potential advantages this stove has [ cutting edge appearance, respectable long burn times, low pollution, great heat performance, good fire view, affordable price point, outstanading Manufacturer Customer Service, and customizability ], it gets harder and harder to beat. Only time and the market place will determine how successful it is. So let the naysayers chatter away until then.
I love the looks of the Progress. I like the look better than any stove I own. I like it better than any BK stove. But, it seems like that stove does not meet my needs when it comes to burn times. I wish it did.
What is your need for burn time and by what definition?
I still think the Englander 30NC is going to be its main competition. At 50% less cost, it is an exceptionally clean burner with a great fireview and super customer service. Personally I don't like the customization, I prefer the IS in all black. However, one can customize the 30NC just like BB did, with a can of Stove Brite. I think the IS is going to have to have some added benefits like longer burn, noticeably greater heat output, etc. in order to make a significant mark in the big steel market.
I was disappointed with the reports from the Cape Cod. Great looking stove. But, at 3 cu ft, those burn times should have been better. The reason why I feel that the Steel will provide longer burns is that I heard that Woodstock allowed for the steel stove to burn at a lower output than the Progress. So, that should mean consistent burn times in the 15 hour range. We'll see if that holds true.
Agreed. if 10-12 hours is the end results, the lower price point isn't low enough to compete with the economy steel stoves. For half the price I am getting 10-12 hours from the 30.
Keep searching...eventually you will find what you need. For my current situation, burn times of 12 hours are ideal. I am fortunate enough to have been able to take early retirement, so I enjoy interacting with my stove, and have the time to do it.
We will just have to wait and see.
Usuable heat is my definition of burn time. 15 hours during the coldest temps (highs in the 20s, lows in the teens to single didgets) and 20+ during milder temps
I just can't believe it will be in the 10 to 12 hour range. They would have had to take a pretty large step backward to only get 10 to 12 hours of meaningful heat out of such a large stove.
Reactions: Highbeam
Yeah, then the PH is probably not for you. Really, I think only the King meets those definitions. With your heat needs, I doubt you'd be able to 15 hours in the coldest weather with a Princess.
I just had a 12 hour burn with the PH last night with the low down to 3 degrees. I could have easily reloaded after 15 hours, but wouldn't have gone past 12 because I needed the heat.
12 hours seems to be the sweet spot for most of us.
