S
That's a good deal. I love mine...
You'll be amazed at what you'll find yourself using it for. My most common uses are:
1. "Sweep" the garage and shop.
2. Clean off the mower after use
3. Dry the vehicles after washing
4. Clean out the bed of my truck after hauling stuff
5. Getting a brushpile going
6. Leaf clean-up
Might want to check with your Stihl dealer. Mine always has some older stuff around that he lets me get parts off of.Yeah it was a great deal! It is missing the air filter and air filter cover, and the end of air tube.....all cheap parts on the internet. I was prepared to have to get another carb for it because it was torn apart and missing screws and stuff, until I noticed it is basically the same carburetor as my polesaw and I happened to have an extra carb in the shop. Took the parts I needed off of the donor carb cleaned it up and rebuilt it, blower fired up on the third pull.
BG55 is/was a great unit. I've sold 'em to family!
But I dunno scotty, isn't that machine a bit new for you? After all it doesn't have reed valves OR points .........!!
Nice, I have a BG85, Think the only difference is that the 85 can be converted to a vacuum. Used it a few times in that mode for cleaning leaves but it was slow.
You have to attach a bag to the air outlet, the inlet is hinged, swing it out of the way and attach the suction tube. Then the shoulder strap is almost mandatory because the whole configuration changes. I don't think it would replace a shop vac.
Have fun with the new toy.
6. Leaf clean-up
Don't forget 7. Light snow removal.
