Wolves1
The main question is wood moisture, if there is any piece of wood that has over 20% moisture after split that will cause blacking of the glass. The other thing that will add to the blacking is if you cut the air to soon. Also if you cut the air all the way and the fan is on that cools your stove and will also blacken the glass, just open the air a bit more. I also found that when you start filling the stove and burn 24/7 when temps drop that will cause a stronger draft and the glass will stay clear. It is a cat stove and the bottom corners will get black but you should still have about 75 to 80% clear viewing.View attachment 215869 Hey folks. I’m a new owner of this unit. It’s burns nice and hot, especially with Cat engaged. I am having the same issue as many others. The glass gets black easily. After every overnight burn i wake up to a 40% black glass. Sometimes more like 75%. Seems worse when I turn on the cat and turn down the intake airflow. And cleaning it is not as easy as previous stoves. Seems to stick more. Anyone have suggestions about how to clean glass better in this unit? Especially when hot. I want to burn for days straight and don’t want to wait for the unit to cool down before cleaning.
![[Hearth.com] The Regency CI2600 & CI2700 operation thread [Hearth.com] The Regency CI2600 & CI2700 operation thread](https://www.hearth.com/talk/data/attachments/216/216582-eaf51f25bb30c801fe63992038467723.jpg?hash=-SYAzxsykL)
