Warning going totally geek-oid below.
So, I just finished hauling in the last of one of my rows of mainly black locust. There was a very mynute scattering of black walnut and oak in it as well. I also burned a small row of poplar earlier in the fall. I decided to see if what I burned volume-wise matched what I burned weight-wise. I use -SWEEPS- library for all weights and BTU's. The wood has been split, stacked on pallets and top covered since 2014.
Here's the theoretical weight of what I have burned and had sitting downstairs waiting to be burned; which consisted of the following two rows, by volume:
- 0.53 cord (as measured in my spreadsheet) of poplar .....poplar is 2,210lbs/cord = 1,171 lbs
- 1.14 cord (as measured) of mostly black locust (sprinkling of black walnut and oak).... black locust is 3,740lbs/cord = 4,264 lbs
Total theoretical weight based on measured volume = 5,435 lbs
I then weighed all the wood I currently have sitting downstairs and added it to the weight of the wood I have already burned this heating season. This encompasses all the wood in the rows mentioned above. This total came out to be 5,348 lbs. A difference of only 87lbs!!
Pretty darn impressive, considering not every single piece was cut as long as 20" (which is what I used for the volume calc.) and there was a sprinkling of black walnut in with the BL.
See how much fun one can have when they weigh all their loadings.
