Getting plans together to hook up the T5 Alderea in the living room of our 1 ½ story cape code.
It is a corner install. The house has a semi-finished attic only. Roof is 8/12 pitch. [edit: 10/12 pitch]
Basically I have 2 ways to run the Duratech class A.
1) I can go straight up from the stove through the attic (about 2 feet of attic space) and extend the Duratech up to proper height above rook ridge (about 12 more feet).
2) I can do a through the wall system. I would have to exit the house on the gable end and use the normal 90 elbow of stove pipe and then the class A tee, etc.
My concerns between the 2 setups are:
1) Ease of cleaning
2) Aesthetics
3) Safety
4) Efficiency
I suspect the straight up will draft better.
I am concerned a lot about cleaning. With the wall setup, the tee (being at head height outside) will make for easy access with no dirt inside. But I would still need to disconnect the inside DVL stove pipe each time to clean it.
With the roof setup, I am NOT sure how to even clean it.
The rain cap’s height will be far too high to get a brush down the pipe. Is it common or even doable to remove a section of class A every time to clean? The lower section (at 5 foot) will have a roof support strap around it.
I don’t like the idea of cleaning from the bottom, up.
As far as aesthetics, I think the roof setup would look less “conspicuous”.
The chimney is on the highly visible, road side of the house.
Hope you guys have some ideas/suggestions/insight that I may not have thought of. Thanks.
1) Ease of cleaning
2) Aesthetics
3) Safety
4) Efficiency
