ticking noise heard - kind of annoying
csierotnik
39
Syracuse, NY
Hey all,
I had the stove running tonight and I noticed a ticking noise heard - guessing it is coming from ss rigid pipe coming out of collar. I have a Lopi answer a-2 insert installed in my fire place. I have a straight ss pipe coming out of collar connected to a ss 30 degree elbow that goes into a ss inulated liner. I had the stove at 400 and flue temps at 190-220. Any ideas what is causing this noise. Is it just the SS heating up?
Both my old steel insert and my current 30-NC started/start ticking at four hundred degrees. Great way to tell me it is time to start turning down the primary air.
Stoves tick. That is what they do. Metal does not expand quietly.
How long is the ticking noise happening? It could just be normal metal expansion from the stove heating/cooling. Or, there could be a loose part on your air intake that may be flapping/ticking.
If it's a rhythmic ticking it may be normal. If it is more of a quiet crackling sound in the flue pipe, it can be creosote burning off.
Thanks for the quick reply guys. It is definately more rhythmic. I ll take that as my sign to start shutting down the primary air.
Thanks again!
Thanks again!
Maybe, that is just where BB's starts ticking. Yours may be different. As others have said thought, metal expands, it makes noise.
tfdchief said:
Thanks again!
That Buck doesn't tick Chief. It is groaning. From old age. :coolsmirk:
My T5 is always making noise. It can be annoying at times, but then I think about all the free heat that I'm getting out of it and for some reason the sound just disappears.
The chase for my chimney runs through the bedroom so the ticking from the liner cooling lets me know it's time to reload
The sound is not loud enough to be annoying or wake you but enough to get your attention
Aaron
Don't cut the red wire!!!!! ;) :)
The sound you hear is the sound of cheap heat . . . embrace the "noise."
It's a ticking bomb!
Actually it's a great feature to have an audible identifier to the rapid (or not so rapid) temp changes, I'd invest in a magnetic thermometer. This way you'll "see" the ticking.
On my Answer, a slow ticking sound (tick.................................tick...................................tick) means it is slowly heating up on cold-start or warm re-load. If I turn the primary air down too quickly, I'll get a fast tick as it cools down (tick.tick.tick.tick.tick..etc.). You'll soon be able to tell the difference between the two and know whether you should give it more primary air or whether to watch it for overheating and be ready to turn the air down.
