Hello,
Love the forum. Lot of good info. First wood stove and first post.
I have read all kinds of technical manuals on various stoves. I still have not picked the exact one yet but here's my situation.
All speak of clearance to "combustible walls" and how to reduce this space with proper shielding, etc.
I recently tore out a zero vent fireplace in a small weekend home I just bought and will be replacing it with a wood stove.
My intention is to build up the hearth to the manufacture R-Value with the final layer being stone or tile. This I understand and does not seem to be a big challenge as long as the coverage meets specs for the particular stove.
My general question is this:
Instead of placing a shield with 1" spacer off the existing combustible wall I would rather just build a new wall 1" away from the existing wall and make it out of metal studs, durock, and tile or rock. I would do this all the way around for a 24" alcove installation. Half the stove would probably be in the alcove and half out. Left of the new alcove with be a 48" TV center and to the right a small pantry for the kitchen. Every inch of the wall is going to be used. If I do it right, it will leave a 36" walkway between the stove hearth and the bar top.
Since the new wall will be non combustible does this meet the same specs? It seems to me that it would exceed those specs except that there would be no 1" are gap under and over the new wall as like you would have when just hanging the durock on the existing wall.
The followup question to this design is where to measure after the wall is complete? I assume that it is still to the combustible wall and not the new wall. So, for example, if the unprotected specs read 12" from the side of stove top to a combustible wall and the new wall is 1" away and is 4" thick then the stove could actual sit as close as 7" to the non-combustible wall and still be 12" from the combustible wall.
If this is true does this also apply to the back and top of the alcove if I also make them non-combustible with at least a 1" gap between the old wall/ceiling and the new wall/ceiling?
Actually the ceiling part would have about 1 foot of airspace between the new non-combustible alcove ceiling and the existing ceiling.
Is my thinking correct? I believe it is, but want to make sure before I start cutting and screwing.
Attached is a picture of my starting point. The old chimney will be remove and replaced with UL103HT specs. Might even have to move it to the right a foot or two. Patch and cut, patch and cut. Yeah fun!
Thanks in advance for any feedback.
)Attached is a picture of my starting point. The old chimney will be remove and replaced with UL103HT specs. Might even have to move it to the right a foot or two. Patch and cut, patch and cut. Yeah fun!
And that bushy beard of his.
stove top temps ( do not attempt= meltdown) would be easy with Properly seasoned wood. Secondary burn, overnight burn, and 24-7 heating should be easy with the properly sized stove (unless your heating a small area). Tell us more about your set up; sqft, 1-2 story, lots of windows, open floor plan, drafty/tight, well/poorly insulated, primary/secondary heat, etc.
. It would be so easy to burn 24 hours, why not. Now that you posted the details, others will chime in.
) loads on the right. Or is your pic flipped?![[Hearth.com] To combust, or not to combust, that is the question. [Hearth.com] To combust, or not to combust, that is the question.](https://www.hearth.com/talk/data/attachments/72/72310-35f50dd9af7bb867c053ee7b1722c485.jpg?hash=PjpqNbvL7Y)
