This has come up for me before and I abandoned it... but I'm wondering again whether I should stop using use my ash pan to clear out the ash and let it fill up and forget about it.
If my stove had no grate but a wee hole, like some stoves do, into which to rake ash I think I would use it, but with a grate you can't sift ash and save coals; whenever I empty the ash out of the pan, it 'grates' on me to see the amount of good coals that fall through the grate as well... What a waste!
Even though the area below the grate does seem to be airtight, I also can't help but wonder if filling that area will improve burn times..it seems that lots of folk here think it does.
So, I've been letting her gradually fill up with ash till it's an inch beyond the level of the grate, not only so I get a good bed of ash and coals to burn on (not possible with a functioning grate, as so much naturally falls through) but also in the hope that the coals will be burned away to a finer ash and not wasted. It's still got a little way to go till is full... Wow, it takes quite a while!
I will of course also be keeping an eye on how a fuller ash bed effects the burn..
Possible cons:
- I've been told that stoves with grates need to be used that way, or the grates over heat and warp. True?
- I've read elsewhere that the ash left in the pan will become damp in the non-burning season and could rust parts of the stove. True? (i could empty all the ash out at the end of the burning season of course, but suspect that would rather not be bothered doing this.)
- would it eventually get to the point where the ash got impacted and solid that it might become almost impossible to ever get the ash drawer pulled out any more?
Has anyone else out there, with ash pans and grates, tried both approaches and if so, are you able to offer any advice, pros or cons to either the 'ash pan or no ash pan' approach?
Possible cons:
