Too hot 🥵
J.P.
2
Oregon
I have an Comfortbilt HP 41
I have tried Manual 1 and it gets up to almost 89 degrees
Then I tried setting temp to 65 and same thing 89 degrees
If I set it to temp/ eco it will shut down and start back up but uses more pellets and it doesn’t take long to reach temp and shut down again !
My feed rate is on 06 off 25 on manual 1 from the factory !
Any input is appreciated !
Mine did that once when I first got the stove before I had finished setting it up. The external thermocouple had fallen on the floor and stove was trying heat the house to 75F at the floor surface. Just lifting it up a couple feet fixed it.
How well sealed is your home?
What is the outside temp?
How much area are you heating?
If it is getting too warm on #1 Manual, to
means the house is well insulated and sealed.
You may be better off to set the stove on temp
mode at 70-72 and let the stove cycle on and off as necessary
It was 37 this morning and my house is not sealed well at all ! I’m in a 1000 sq ft house built in 1980
