drtnshtr said:
Ok I may have screwed up then ...I ran insulation as high up in the knee wall part of the attic as I could and it ran it all the way down to where the soffit is. Maybe I am blocking some circulation?
If you look at the unheated attic space outside the knee wall as a triangle, with the sloped part being the roof, what you want is for the air to be able to circulate freely from the soffit vents to that unheated space, and to be able to continue up the slope to the area under the peak of the roof. You can insulate the horizontal and vertical sections (finished attic wall and first-floor ceiling) as much as you want so long as that air circulation isn't hindered. This page has a diagram showing what I mean, scroll down to 'figure 3':
http://www.cmhc-schl.gc.ca/en/co/maho/gemare/gemare_001.cfm In new home construction, they now use what they call attic vents (made of styrofoam or cardboard) stapled to the underside of the roof sheathing between each of the trusses to ensure circulation from the soffits can't be completely blocked.
That said, blocking that air circulation isn't going to have a significant impact on your heating costs/efficiency. What it is going to affect is the life of your roof. Lack of sufficient outside air circulation is one of the primary causes of premature failure of asphalt shingles. It can also cause snow on the roof to melt, and refreeze, forming ice dams that get up under the shingles and then leak into the attic. (assuming you are in an area where you get snow)
