Well, we've been stove shopping and through the process of elimination,  we seem to be settling in on either a Harman Accentra 52i Insert or an Enviro M55 Cast Insert (52K & 55K BTU).  We did look at free-standing but our fireplace is 39" from the very back to the end of the hearth and there is only 15" from the fireplace wall to the end of the hearth (level with floor).  Because many free-standing have either controls, clean-out ports or hoppers toward the back of the stove, it would have to be largely out of the fireplace alcove and the boss doesn't want that as it will make a small living room seem even smaller.
My house is a center-chimney cape wherein the center living area (LR, DR, KIT, & foyer) is 624 sq. ft., the bedroom upstairs w/bathroom is also 624 sq. ft. A breakfast room off the KIT is 169 sq. ft. and the ell off the living room (bathroom, office and bedroom) off a common hallway is 480 sq. ft. The house as a whole would not be called open-concept. I was in large home with an Accentra running and it was 77 degrees and it is 2200 sq ft. on the main floor and I wonder where my home is smaller would the Accentra or Enviro be too much stove. As I understand it, with either stove I can select 70 degrees and the stove will try to maintain that but will it be so under-worked that problems might arise? If those in the know feel it might be, are there other inserts that might make more sense with BTU ratings between 35000 to 45000? Thanks in advance.
Paul
Paul
