Is that pink stuff the hinge?!!I usually cut those up higher in an attempt to find more solid wood. That said, I've never cut anything that bad; They usually fall down before they are that far gone.
No, ladders and saws equal trouble!No, the semi-circular white part at the bottom of the 2nd picture.
True - coulda, shoulda cut higher up but I didn't want to be on a ladder that far from a hospital.
No, ladders and saws equal trouble!That said, I've gotta make a cut from a ladder, I may do that today. I cut a Red Elm but it hung up before it could get any momentum going. I'm make another notch and back-cut from a stepladder but since I've already got a rope around it and will break the hinge pulling with the quad, I can leave the hinge fat and the tree shouldn't budge while I'm on the ladder. Pray for me.
OK, looking at it more I'm getting a better idea of how it went.the semi-circular white part at the bottom of the 2nd picture.
That's pretty much what it turned out to be. Made the second cut, pulled it and it dropped out of the first snag and fell sideways into another one.sounds like you have a Rube Goldberg plan for taking it down!
I find on sketchier drops if I make my back cuts on more of (geometrically speaking less of) an angle to my wedge cut I can see where the tree is going faster and react better if needed, and the tree is less likely to go all the way the wrong way as there is support behind your cut. It's also easier to cut your saw back out if it gets hopelessly pinched.
where is Yoop?
I knew, only because I grew up in WI. If you grew up in central America, say MO, you might never have heard of a Yooper.the U.P., phoneticized in to "da yoop".
And you moved to IN? That's wedged right in there between the trolls and the FIBs! That should drive even a cheesehead nutsI knew, only because I grew up in WI. If you grew up in central America, say MO, you might never have heard of a Yooper.![]()
Wow, that one was a tall boy. You gonna get that leaner that comes into the picture as it pans right? What kind is that one?put the video of the fall in the first post.
Trolls and FIBs are more of a problem in the northern part of the state; Rednecks are the issue down here.And you moved to IN? That's wedged right in there between the trolls and the FIBs! That should drive even a cheesehead nuts![]()
Went back out yesterday since a cold front came though. Thought it would be comfy but with the high humidity I still ended up taking a sweat bath....didn't help when I had to chase two rounds that got away from me down into the ravine, and pack 'em back up top.
Thanks Missouri! Local slang for the Upper Peninsula of Michigan. Upper Peninsula aka the U.P., phoneticized in to "da yoop".
Sure. Daughter was manning the camera. I was pounding wedges into the cut moments before the fall.FYI, if you turn your phone sideways, the video comes out much nicer.
