I have been combating a problem in my condo for about 1.5 years now. The companies hired to inspect/clean the chimneys tell me there's nothing wrong there & I have tried a variety of DIY cleaning solutions of my actual fireplace to no avail.
Basically I have a traditional fireplace in my condo that's encased in brick, with a flue that opens up into the chimney stack, and the front of the fireplace is a sliding glass enclosure. I normally purchase fireplace wood from one of the big box stores like Home Depot or Lowe's every cold season along with some Duraflame logs to mix things up. I use the fireplace as an alternative to running my electric baseboard heaters when I'm home for long durations (eg. weekends).
Regardless of what I'm burning in the fireplace, I am finding my condo fills up with a light smoke haze and eventually completely smells of smoke. Growing up in a single-family home with a traditional fireplace we never had these issues and I'm torn as to what to do. I'm most concerned that the stagnant smoke and smell will trigger the entire building's smoke alarms forcing a visit from the Fire Department for no emergency reason.
I'm here to ask for advice/help on whether this is normal in this type of setting (the condo is only 880 square feet total), if there's potentially an airflow issue causing this, or perhaps the solution is as simple as burning a different type of wood or product.
Any help would be appreciated!
TIA
TIA
![[Hearth.com] Traditional Fireplace Issues [Hearth.com] Traditional Fireplace Issues](https://www.hearth.com/talk/data/attachments/235/235999-ca2dbf79b183b5a96b5b586c6c2ee2e9.jpg?hash=WrF7j_pUaZ)
I will still have to manage the draft with a cold flue, but I don't think it will be nearly as much of an issue, in part because the smoke will be contained in the stove and the pipe up the chimney.
