Read all I could on this forum and decided to just try some different seasoning methods myself. I live in central NC and am trying to get my wood supply set up for next year. Just built a new house so I am starting from scratch. All the wood is from a recently fallen red oak (with the exception of a few rows of pecan on top of one of the IBC totes). All wood has been split between December 30 2020 and January 21 2021. The goal is to have firewood ready to burn next fall and simplify the handling of it.
The methods I am trying are:
1) Stacked 2 rows wide (8-12" air gap between rows) sitting off the ground. Top is covered with a tarp
2) IBC totes with the tops covered
3) Ventilated log lift bag sitting on a pallet with the top covered
One early observation is that the firewood bag holds a little less than the IBC neatly stacked. Also, if you are going to move the firewood bag you have to use the straps. it is unstable sitting on a pallet with anything less than perfectly level ground.
Depending on moisture content in May/ June, I may build a solar kiln to ensure my wood is ready for next fall. The location gets abundant sun and lots of wind. It is on high ground and stays dry. If I do build a kiln, I will measure the moisture content of each before using the kiln.
I have lots more to cut between now and then but this first batch should get us going for next year. A recent storm left 2 red oaks down that measure 36" and 40". I have at least 5-6 cords left to gather.
Appreciate any opinions and other methods I should consider.
Attached is a picture. Still have to cut the lid for one of the IBC totes.......
