Moisture Content of Firewood? Good Information
That's true...but for some reason the reading seems to change a bit with depth...contact surface area maybe?
It's not the depth of the MC that is the issue, it's The contact resistance that's the issue. It's a two-point measurement and the contact resistance is in series with the load you want to measure.
Having tips not in deep increases the contact resistance leading to lower mc readings.
Here is why you Do need to sink deeply, or add a few percent to a non deep reading.
Got it, thanks 👍🏼
Reactions: stoveliker
You can bend the tips of the bent pins back to straight with plyers if you are careful.
I tried that. Cheap garbage from overseas, they broke right off. The tips did anyway. I kept it. I might see what it takes to put in removable pins. It's way down the priority list though.
