I have a similar setup. P68 in basement of 1,200 sqft ranch. I do have two registers, but when I put my foot/hand on one (located in same room as stove), I barely feel heat! My guess is distribution blower is blowing most of heat past to where the register is. My P68 is about 10 feet from the stairs.
I have a fan in the basement pointing up the stairs and a register in the floor too, and have noticed that the cold air on the floor is pushed down as the fan is pushing the hot air up. So basically you will not feel any hot air from the register. Try and put your hand over the register in the basement you will feel it.
Not sure I'm following you. So your saying I'll never feel the heat through that register?
care to elaborate why?Expect a 10 degree difference in temps form one floor to the next.
Even with a strong air current you wont get the other floors as warm as the one where the stove is. The stove room is benefitting from radiant heat as we as hot air.care to elaborate why?
So your fan is in the basement blowing up the stairs? Currently mine is in the living room, blowing towards the basements stairs- but the fan doesn't have a line of sight to the stairs. So if we don't feel heat - the whats the point of the registers - are they just to complete the loop for the circulation of air?
Is your basement a large single room, or multiple rooms divided by walls and doors? I'm just trying to establish if your basement is receiving the benefit of radiant heat b/c there is only a single room.Even with a strong air current you wont get the other floors as warm as the one where the stove is. The stove room is benefitting from radiant heat as we as hot air.
In my house while the basement is 85 (where the stove is) the floor above wont get warmer than 75-76 even with a lot of air moving.
My stove is located on my first floor in a back room and can easily reach 85-90 degrees. The rest of the first floor will maintain 75-78, but only if i run fans to distribute the heat to the rest of the first floor rooms.
My second floor does not receive this same benefit, and I am lucky if it gets to 70-72, and trying to find some options for this.
So it would seem that your statement is not necessarily related to heat movement between floors, but just to heat movement in general and not receiving the benefit of radiant heat.
My stove is in a separate 18x20 room in the basement and yes it gets 90-95 degrees in there. The adjoining room 24x24 stays about 85. From there I direct the air up thru a floor vent to the 2nd floor family room and kitchen which stays around 75 ,and the 3rd floor where the bedrooms are stays about 68-70. Each floor is about 1000SF. 3000 in all. This takes moving a lot of air. I never tried it without the fans. I assume the temp differences would be much larger.Is your basement a large single room, or multiple rooms divided by walls and doors? I'm just trying to establish if your basement is receiving the benefit of radiant heat b/c there is only a single room.
What are your outdoors temps with those indoor room temps? Wondering how they shift for each outdoor 10 degree drop.My stove is in a separate 18x20 room in the basement and yes it gets 90-95 degrees in there. The adjoining room 24x24 stays about 85. From there I direct the air up thru a floor vent to the 2nd floor family room and kitchen which stays around 75 ,and the 3rd floor where the bedrooms are stays about 68-70. Each floor is about 1000SF. 3000 in all. This takes moving a lot of air. I never tried it without the fans. I assume the temp differences would be much larger.
If you have central air in your house you should maybe look into ThermGuard http://www.bearmountaindesign.com/
I dont run my stove unless its below 40 outside. It just gets too hot inside. Once the stove is up to temp the air setting is turned all the way down. I burn mostly pine. Oak for overnight sometimes.What are your outdoors temps with those indoor room temps? Wondering how they shift for each outdoor 10 degree drop.
