This is a really important post I think.
I wonder if the setting should be different depending on how you run your system. This is my 4th season burning with my Eko-my best no hassle, cleanest, effective season yet, mainly because I have added storage and changed my plumbing to heat my pressurized tanks, then draw heat from these tanks. Other seasons involved heating my zones directly from the Eko, then the return would go into a single 500 gallon tank. New Horizon recommended this setup to me by the way, and it set me back 3 years the way I see it.
So my point is, before I would try everything I could to stretch out a burn, while now I try to heat my storage and live longer off of the stored heat. I'm only guessing that it might take different air settings for each. I know this season is the first season I put the cover back over the fans, while other years I had to constantly adjust the pie holes
manually to get the most out of a burn.If I got behind on the fire (other seasons) I had to run wide open for an hour or so, then close them back later. Sure, all of this can happen because I was home. So anytime I left it was a disaster. Probably some of this due to the plumbing setup.
Meanwhile I am going to follow what noffosil, sroberts and some others do because my system is now similar to theirs.
An additional opinion is this. Before adding storage and changing my plumbing, I would not have recommended this kind of system to anyone. With my new setup, well, it's like trying to spread the good news of Jesus Christ. I am guessing also, that my error was an oversized boiler, and not quite enough homework when I started. This battle to keep warm has become quite the hobby.
By the way, I thank the inventor of this forum and all who have helped others once again. Without you I would be-cold
