Yeah, what's the closest city so we can pull it up on NWS..? 54 here right now..stove about out.The cold is in Idaho now? It's certainly not here.
I'm south of Moscow, east of Lewiston, and west of Orofino. It's merely chilly.Yeah, what's the closest city so we can pull it up on NWS..? 54 here right now..stove about out.
Today was like the February days I remember from 40 years ago. Clear, sunny and freezing cold. I doubt if it got above freezing all day. I started a fire in the yard to get rid of debris, and it melted off the snow and thawed the ground around it, but as it died down the mud started freezing again.That's quite a departure from your normal temps, then.![]()
It was getting chilly about the time the sun started down, so I fired up the Hearthstone in addition to the King. It is quite toasty inside tonight.
I run two stoves October thru April. It loses its luster pretty quickly, when you’re loading x2 every night, and doing double ash pan duty.
... and to think I was trying to convince my wife to install a third stove, just a few years ago!
I was thinking pellet for upstairs. Two stoves mean double the wood cutting/stacking/loading. If I lose power or on milder days I'll just run the wood stove.We run two stoves too. One is a pellet so it breaks up th routine a bit. It’s actually pretty nice having one of each. They both heat on different principles, one radiant and one convection, which adds flexibility to the overall heating scheme. Depending on outside temperature and our schedule, we mix and match which stove(s) to run, when, and for how long. For example, if we run the wood stove during the day and let it go out in the evening, the pellet stove on a low idle will keep the house warm all night. That’s using only 20 lbs or so of pellets. The pellet stove takes a bit of wood work load off me as well.
