Would running a mix, say underfloor hydronic, on the first floor, and conventional convectors on the second, be a problem? I can see a bump in convector capacity would help.
By which you mean, nate379, that you have to run at desired temp all the time because it takes to long to heat up?
Where do you live, Dextron, with that 90* radiant water keeping you warm? I don't think there are enough BTU's anywhere on the coast of Maine to keep my place warm....
Why are you loosing 20* from your floor temp to your air temp?
If I set my T Stat to 68*, the floor might get to 75* in the warmest spots. My water temps at the boiler are about 130* and usually the return temp is 100-110*, depending on slab temp.
As for floor loops running all the time, that is not the case in most systems that I have seen, and was not the case in the one I lived with and redesigned to run off of an OWB. That system was on demand and originally run off an electric boiler that came on when the standard wall type thermostat called for heat in the house.
The OWB water loop ran constantly, between 160 and 185 deg. F. If we left on a trip in winter I closed off the OWB loop and turned on the electric boiler and dropped the t-stat to 50 deg. F.
My setup is in a 4" slab for the house and 6" for the garage.
Yeah. Takes several hours to warm up a few degrees. With using the stove it goes cold more or less so it takes 10-12hrs for the slab to get enough heat in it before it will really start doing anything.
One year, 2010 maybe, I was gone for 2 weeks in the winter and I had turned the heat to 45*. I got home late after a LONG flight, no mood to mess with the stove. Kicked on the T Stats to 68* and when to bed. Got up about 10hrs later and it was barely over 55*. I let it go just to see and it took close to 24hrs to get up to 68*, roughly 1* an hr.
The other thing I don't like is there is no between room air exchange. If I were to design my heating system I would include forced air, maybe not even do the floor heat.
Stihlhead--don't these two statements contradict each other? This is what I don't understand about these systems: do you have to run pumps constantly or as needed?
Your system should respond MUCH faster than that. Two stage thermostats would solve this problem. When the second stage contacts close (you turn up the heat more than a few degrees) and the outdoor reset is bypassed and the supply to the slab goes into MAX setting ie. 130 or something depending on flooring. This would make the system burn more fuel but only to keep you happy. Outdoor reset is keeping the slab only a few degrees warmer than calculated to keep you at 70 or whatever the calcualtion was based on. This is for fuel savings and con
stant circualtion or near constant circulation. This is how I would solve your problem with minimal hardware. The hardest thing may be pulling thermostat wire with the extra conductor if you only have standard 18-2 wire now. I generally pull some CAT-5 or 22-4 for this very reason. Someday someone will want to do something that needs more conductors than the standard two.
As for scorched air furnaces, well no comment, mobile homes come with them for a reason.
TS
I have a mixer connecting the primary and secondary loops of the boiler and I have it set to around 130*.
There is your slow response problem. The reset is only controlling the boiler temp saving some fuel. The fixed floor temp is causing the slow response time. If the floor were on a reset control and the two stage thermostat, you's get different floor temps based on outside temp, and thermostat call (primary: reset temp, secondary: high temp).
A fixed temp system is good for small radinat retrofits, but a large slab under living space (not garages or something) respond very well to a motorized mixing valve or injection control via outdoor reset controller.
TS
Stihlhead--
Why does the OWB loop have to run continually? What would be the least-operating-cost way to run the radiant loop?
And I imagine without heat transfer plates, you'd have to run your radiant floor at a high temperature. What temperature does anyone here run their radiant floor pex? With or without heat transfer plates?
I think it,s called "putting things into perspective". People go through life with all these things happening around them and don't even question them.But I digress.......
