Unsure about pipe temps
LAndrim
116
Outside of Philly
Hi Everyone, just got brand new Lopi Liberty hybrid wood stove. It came with an internal thermometer (catalyst monitoring probe). On my old stove, i drilled a hole in to the pipe and used a con air probe.
Question: should I rely on the accuracy of this Lopi probe or drill and use the ConAirprobe? thanks all!
Reactions: Burnin Since 1989
That factory Cat probe will dictate when you engage the Cat and help you keep your air adjustments at a level that keeps the Catalyst active for the longest duration.
Installing a temp probe in your venting hurts nothing. I wouldn't rely on it to operate a Cat equipped stove.
It's possible you may see much different exhaust temps with this stove than you are accustomed to. Generally, cat equipped stoves will have a very low exhaust temp when running lower and slower than a non-cat stove.
Thanks much moresnow. Good to know about the cat probe; I now understand. Thanks!
But I still am unsure how to judge the burning temp; I don't want to overfire. Any suggestions?
I don’t have a Lopi but with my Fireview I rely on flue temps on when to engage the cat. There is less lag time reading flue gasses than waiting on stove or cat temps. When I had a cat probe in the past it was a good indicator if I had a stall or if the cat needs some cleaning. Probably good to have both of you really want to fine tune your burn.
The probe thermometer will provide more data. By Con probe, does this mean Condar? That's a good thermometer and will help with knowing when to turn down the air. However, it takes a bit of time to react so don't be afraid to turn down the air a little early if the temp is rising quickly.
Sorry, yes, i meant Con Dar, not air! No need to respond. Thanks
