I have the Hearthstone Shelburne 8372 model on order. Has anyone gotten a straight answer on what temp the cat becomes active? I know the thermometer that comes with the stove does not indicate the temps only the inactive/ active and too hot zones. The manual is a little wishy washy on the subject. Initially it says the normal operating temps are from 800-1300 degrees F. Later in the manual is this gem " -This catalytic (or hybrid) heater is equipped with a thermometer to monitor catalyst operation. Properly functioning combustors typically maintain temperatures in excess of 500 °F and often reach temperatures in excess of 1,000 °F.
Has anyone used a digital probe meter (ie Auber) or swapped out there original thermometer from Hearthstone with one that shows temps?
If so, what kinds of numbers are you seeing?
Does anyone know the length of the probe on the OEM thermometer?
Any and all help, appreciated!
