...been lurking for a while. Finally took the plunge and joined. Glad to share in the wealth of knowledge here.
This post brings two main questions:
1. What is this?
2. How can I upgrade?
A little background here. We live back in the mountains on the state line of Tennessee and North Carolina at an elevation of around 2,300 ft. It is not out of the ordinary to see temps dip below 0 for 5-10 nights out of the year here oddly enough. Our house is a 1,300 sq ft rancher built in 1971, insulated fairly well with new windows going in this fall. Eventually would like to rely solely on wood for heat as we have been blessed with a plentiful wood supply.
Now, the current setup. 33"w x 24"h x 24"d fireplace with 1/4" steel plates welded in to make a box, and ~8" clay lined exterior chimney (about 15-20 ft). The fireplace has 2 240v heat pump style blowers with two separate intakes on the hearth. Two outlet vents above the fireplace allows the air to be blown into the living room. Here is where things get a little different. The vents above the fireplace can be closed, causing the air to be forced through the duct work in the basement. Each room in the house has 1 vent in the floor connected to the fireplace. Also in the basement is a giant ash dump directly under the fireplace.
My chief complaint from this set up is the same as most...too much heat up the chimney and too much wood being burned. It's borderline amazing how fast you can blow through wood.
The obvious answer is to throw in an insert and stainless liner and call it a day. However, given the setup, is there any way to capitalize on the HVAC style system hooked up to it, or will an insert alone be enough to cover 1,300 sq ft.? Also, do you bother with cutting out the old steel plates (not knowing what is behind it) for extra space or leave it be?
...got a few ideas, but I'd like to see what the general consensus is before I start hitting on specific models.
Thanks in advance for the help...and for the knowledge already gained from this site.
Here are a few pics for reference. The wife covered the intake vents with decorations after we quit burning this spring.
1. What is this?
![[Hearth.com] Upgrading (Homemade?) System [Hearth.com] Upgrading (Homemade?) System](/talk/proxy.php?image=http%3A%2F%2Fi24.photobucket.com%2Falbums%2Fc47%2Fjcmjqb3%2FIMG_02771_zpscryzathy.jpg%7Eoriginal&hash=5b29171f3473d3e4826e75915bafca29)
![[Hearth.com] Upgrading (Homemade?) System [Hearth.com] Upgrading (Homemade?) System](/talk/proxy.php?image=http%3A%2F%2Fi24.photobucket.com%2Falbums%2Fc47%2Fjcmjqb3%2FIMG_02751_zps3itjqlow.jpg&hash=c0c31f0814e75627ae68605dc57c0e4d)
![[Hearth.com] Upgrading (Homemade?) System [Hearth.com] Upgrading (Homemade?) System](/talk/proxy.php?image=http%3A%2F%2Fi24.photobucket.com%2Falbums%2Fc47%2Fjcmjqb3%2FIMG_02761_zpsyqawkwum.jpg&hash=f9137d5df1ade7fdf727ae860e88f90f)
