Just moved into a new place with a US Stove 2000 (Country Heath 2000)
http://www.homedepot.com/p/US-Stove-2-000-sq-ft-EPA-Certified-Wood-Burning-Stove-2000/202815104
New to wood stoves and we have birds (sensitive respiratory systems aka canary-in-a-coal-mine), read the manual, and as a test burned one RedStone compressed hardwood brick, and while no smoke, did smell the smoldering in the house for a couple of hours. I blame the operator for closing the damper prematurely when there were only a couple of ambers left instead of letting them burn hot.
But, just in case it wasn't the operator, I got on the roof and swept the chimney (stove pipe).
Little did I know that it was directly on top of the $80 USD (ceramic fiberboard) baffle and I poke a dimed size hole in it.
So, I go to remove the baffle and the screws holding the air pipes broke, so I'll have to drill them out.
What I would like to know is....
1) $80 for a fragile fiberboard is nuts imo, can I replace it with maybe 3/8" steel plate (10" x 22.5") or something else more "reasonable" in price?
2) I saw mention of perlite and castable refactory cement to make my own, does that sound legit? and anyone know where I can find it (no store locally carry Rutland 600 12.5lb tub) or a recipe to make the cement?
3) Would hex drive stainless steel screws hold up to the heat of the firebox?
Any advice suggestions welcome.
