This stove came with the house. I'm currently taking it apart cleaning it out and trying to figure out how it works. It has an outside air intake, but I'm not sure it's hooked up correctly. It seems to just dump cold air right next to the room fan. It looks like there should be a second flex hose running from the outer stove wall to the fire box, but the tube to the fire box is capped off. Does any know if that is how it's supposed to be? I would rather crack a window in a spare room or something rather than dump cold outside air right to the room fan...
I'm thinking of adding a butterfly valve type damper between the house wall and the stove, adding a second flex hose between the outer stove wall and firebox, and removing that cap.
![[Hearth.com] USSC American Harvest 6039 OAK set up ? [Hearth.com] USSC American Harvest 6039 OAK set up ?](https://www.hearth.com/talk/data/attachments/134/134814-ba5d67c136e83fc50d198ea296562c77.jpg?hash=gJB48RSiIf)
. I found an area on the manual damper with about a 1/2" of travel where it burns the best. If I keep an eye on the flames and tweak it every once in a while I can coax 150
![[Hearth.com] USSC American Harvest 6039 OAK set up ? [Hearth.com] USSC American Harvest 6039 OAK set up ?](https://www.hearth.com/talk/data/attachments/143/143820-fcc208cf117071020930f5434a547000.jpg?hash=IAvs55JzIJ)
