I would like to put a stove on the first level of my home. It would vent out on my wood deck how would I go about hacking that safe? I also have windows and a door to contend with any suggestions or a "rule book" to help guide me.
Go by what's in your manual and ask your town/city fire dept/building inspector if there are any requirements above and beyond what's listed in the manual.
Mine goes straight out to a T, then up for 4' then 45s out so it can get around the eave and up. Having it come out over the deck makes it hard to clean out the T. I put two bricks underneath for heat protection, but the decking is Ipe, which is extremely fire resistant to begin with.
If your windows and doors are within 4' of your wall penetration, you are required to use an OAK, then your clearance is only 18".
Most stove manufacturers do suggest a minimum vertical run to help expel exhaust from the system in the event of a power outage. If you look in the manual for your stove it will tell you how far away the vent should be from operable/inoperable windows etc....
I'm pretty sure the clearances from inoperable windows is pretty minimal but if the window can be opened they want it a ways away for carbon monoxide issues.
Only 18" if using an OAK is that pretty standard? I was looking online at the manuals for the Englander stoves and didn't see that.. Thanks for the help. I was going to go outside and take some pics to post but it was raining like crazy
That 18" is only for specific stoves, everyone needs to consult their manuals. Further the requirement is to the vent termination not the wall penetration.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
