I see the weldment is the entire unit construction .I’m learning ,I’ll look and see if it’s cast I think it’s steel though.do they both come apart ,as in the sides a nd top etc. Or only the cast unbolt .I have educated myself on TC ‘s ours( Vermont Castings 2340 )being ungrounded j type,are these exposed tip TC’s or did mine lose a probe tip?I see the Tempco MTA01331’s have a probe.I also found there are three type tips grounded,ungrounded,and exposed, mine tests positive for continuity and puts out Mv o.oo cold and up to 26.5 when heated and so works ,for now, I scraped it clean and will reinstall it being careful not to ground it as per your warning but I will replace it as it can’t hurt..I assume it does not matter how far it protrudes into the exhaust as long as heat gets to it?thanks your continued assistance!
After replacing the TC these are my observations,the burner blower works,it does not noticeably increase speed if I turn it up with the switch.(the minimum -maximum rheostat switch on the left side.)the auger is physically turning also,observed from the back of the stove,and is moving the feed block linkage,looking in the fire pot I see I unburnt fresh pellets moving as the auger turns at the very bottom.On the other hand it does not increase speed with the min.- max. Rheostat switch to any significant amount either and ,pellets ,no matter the setting are not filling the fire pot or overflowing or even pushing ashes in the cinder box before it burns up and the the stove shuts down Half an hour ( approx.) the blower fans( right side switch ))seem to be operating, these are my most recent observations and I hope in better tech lingo than my earlier explanations. The sides seem to be cast and un boltable from the bottom. The gaskets all seem good. The stove does not really even get hot before shutdown. The pellets I’m using seem to me to be dry and normal and start burning well ,it simply seems to run out of fuel even though the auger is definitely running.I know this long winded Sorry.
Hello Shooter
From pictures I've seen of the original TC from Tbear, it was an exposed type meaning you see the weld ball of the two conductors.
This doesn't mean that a shielded, ungrounded type TC wouldn't work, the one that I used was this type and it worked fine.
I think you misunderstand how the temperature dial is supposed to work. Turning it up doesn't increase the speed of either the feed motor or the exhaust blower. What it does is to raise the temperature setpoint of the exhaust temp TC so that if the exhaust is below the TC's reported temperature, the feed motor turns feeding pellets into the burn pot. Once the exhaust temperature rises above the setpoint temperature, the unit stops feeding pellets. As the pellets burn down, and the exhaust temperature falls below the setpoint, it starts feeding pellets again.
If you look into my old post, it shows my stove with the side panels off, from there you can see the two round tubes that carry the flue gases from the top of the stove into the bottom and to the exhaust blower. Mine is a 2200. It doesn't really matter though, since the mechanicals and the control board were the same on both stoves.
You may want to check the polarity of the TC wire too, if I remember they are white and red. Red is negative and white positive which is backwards from
The original TC was an exposed junction type, TBear had shared a picture of one he had as a spare from Vermont Castings. the one I used and recommended was an ungrounded shielded type which means that the TC wires are insulated in a closed SS tube.
I think your misunderstanding how the stove temperature dial works. The TC measures the exhaust temperature and sends that back to the control board. The idle temperature of these stoves is about 200F. Turning the dial up raises the setpoint that the board compares with the exhaust and then either turns the feed motor on if it is below the exhaust. Once it is above it shuts the feed motor off. It doesn't change the speed of either the feed motor or the exhaust blower. Max on the dial means that the setpoint is north of 500F.
If the stove is shutting down, then I think that there is something wrong with the TC or the wires to the board. Disconnecting the TC wires should cause the feed motor to stop turning. The TC is polarized meaning that how it is connected is important. The red wire is negative and the white positive which is contrary to standard wire colors.
As far as what model you have it doesn't really matter much since the internals are still Harman. Mine and TBears are the 2200 series, which were the predecessor of the 2340. Attached is a pix of my stove with the cast iron panels removed.
![Vermont castings reliance Vermont castings reliance](https://www.hearth.com/talk/data/attachments/302/302349-9038c79b6c36a110ae10e0aca6e5e38f.jpg)
