Vermont Castings Winterwarm Small blower issues
mkjeep2000
5
Eastern PA
We have a Vermont Castings Winterwarm small. Last year, we'd experience a slowing of the blower while in use. The winterwarm small has a rheostat on the blower. Our rheostat wasn't turning by itself, so I assumed a failure to either the switch or the blower itself. This fall, we had the switch replaced (about $200 for the switch and service time.) The blower has been fine for about 2 months. Now it seems that the blower is only running at 60% speed.
We are frustrated with our local stove shop. Following the switch replacement, they had to return twice as the liner was blocking the damper door from closing. I took care of it myself the third time and noticed they forgot to re-attach the surround correctly. I've called the next closest to describe the issue and they won't call back. I've submitted 2 requests on the Vermont Castings site for them to call me and they haven't. I've searched the internet for anything describing how the blower system works and how to remove it or test it. The list of parts for the VC Winterwarm small only has the steel/iron parts, but no electronics.
The user guide to the stove also mentions a thermometer in regards to the blower, but doesn't say what it does or how it affects the blower.
Can anyone provide me with insight on how the blower system on this works? Are there diagnostic directions anywhere? Are there directions on how to pull the whole unit out to get to the blower? Where can I purchase a new blower, if I need one?
Thanks
Mike
I have not seen a wiring diagram for the small but for the large there is one. While they are not the same, the small was derived from the Large, or so I have been told, so it may be very similar. You can compare to what you have seen and should know. Do a google search for "2000941 winter warm Large" pdf and it is on page 16.
You could pull the unit out yourself if you are good at taking apart and putting things back together. I pulled the fans last summer to blow out the the small amount of ash accumulated over the last 6 years while replacing some other parts. I just took over the living room and laid parts that I took out in a location so that made it easy to put them back in reverse order. You can look at your manual for the exposed parts diagram, but it may not be much help. You may be able to search the web to find pictures of how it is done.
I use Black Swan, <http://www.blackswanhome.com/category/stove-parts1?color=&size;=&filter_category=Vermont+Castings&sort;_order=&items_per_page=8#prodFilter> as they seem to have a large inventory at decent prices. You can also do a web search for Vermont Castings Winterwarm Small parts.
If you find a wiring diagram, please post back as I would like to find a way to increase the RPM just a bit.
Good Luck
I think you are on the right track. The blower motor bearings may be getting dry. When was the last time the blower motor was lubricated and the fan blades thoroughly cleaned?
It looks like the blower assembly is on the rear left side of this insert and that the insert needs to be pulled out to service it. If you need a new motor try Black Swan Home or Woodman's Parts Plus websites. Or take the assembly to a local motor shop and ask them to service the motor/blower.
PS: Do you have the manual? The cabinet parts diagram is on page 22.
(broken link removed)
I'd like to get to the blower and such. I didn't watch the install and can't find any descriptions online about pulling the unit.
I've seen how to slide the surround back. At that point, is the unit just sitting there? Is it as easy as disconnecting the flue and sliding the unit out to get to the electronics (blower and such)?
The flue is attached with a couple self threading screws. When we had the switch replaced, the flue was down too far and our damper door wouldn't close. So, that makes me wonder what keeps the liner from sliding down any farther? Is is supposed to be self supported in my chimney?
I'm a proficient diy-er so with a good description, I'd love to pull this thing out to test the switch and fan motor.
Thanks!
Essentially yes, it's that simple. Disconnect the liner, raise it a couple inches and pull it out enough to service the blower. Be careful with the liner metal, it can be pretty thin and dents easily. If you have a sheet of metal, it can make sliding the stove out easier and won't scar the hearth. Set it under the front leveling screws. I would also recommend having a helper to move the stove.
I would also recommend taking a "before" picture. When the insert is put back, you can use this as a reference. Post a picture of the re-install here if you want to have a last visual check before replacing the surround.
BeGreen - thanks for the reply. When you say "raise the liner a few inches", do I just grab the liner and push it upwards? Won't that push everything up and out the top of the chimney, including the cap?
The cap should be well siliconed in place and not loose. Hopefully there will be enough play to lift it out of the insert flue collar. If there is no play in the liner then it may need to be unclamped at the cap. Be patient and don't force things.
Post a picture here first if you want us to look for confounding factors.
Does someone here know how to put more than one picture from your hard drive into a post?
I pulled the insert out last week and blew out the fans with compressed air. I have a pancake fan on both sides. They spin freely. On the fan, it stated 39watts at 115 volt 60 hz.
Directly in the back, where the electric enters the insert is an electrical bus. The common from the cord is shared by both fans. The hot (black wire) went to the switch (rheostat) off the first bus and returned to the second bus that then powered both fans.
I moved the blade connector for the power directly to the second bus (since the fan stated it ran directly off AC power). The fans now fire right up and blow faster than they ever have. Most of the time we'd run at full speed anyway.
I can post pics one per post, but if you know how to post more in one post, let me know.
Thanks for your assistance,
Mike
I'm not trying to put an installer/repair person out of a job, but will document what I did here. This is a Vermont Castings Winter Warm Small.
1. The setup before starting.
(broken image removed)
2. I removed the plate at the top of the door (it just lifts off) and slid the surround straight back.
3. This shows the liner connected to the stove. I also turned the mounts 90 degrees for the front plate to show how deep to put the insert back when I'm done. In the back left and right are two boxes. They are where the two fans are located. The box you see is a duct to direct the air from the back to straight out the front.
4. BeGreen recommended sliding a piece of sheet metal under the front leveling feet so that it doesn't scratch up the hearth. Great idea! Also, my liner woudn't budge so I slid the insert toward me and shimmied the liner out. Then rotate the unit some for access to the boxes in back. Here I remove four screws from the sides of the box and lean it back.
5. After leaning back the box. Here is what you'll see. The exact same is on the other side. With vacuum running to gather dust, I used an air compressor to blast the dust and fuzz out of the fan blades. The box fan is ebm-papst St. Georgen. The number on it is RG 125-19/06. The fan size is about 7 1/8 x 7 1/8 x 1 1/2 deep. The screw mounts in the corners are about 6.5" center to center from left to right and up and down. The air enters at the center of the fan is exits straight up.
6. Here is a pic on the back of the fan in case you ever need to replace it.
7. Here is the electronics at the back. My rheostat (reostat) switch at the front seems to be reachable from the bottom but would require me to flip the insert on it's side and remove about 10 screws. Too much work. I'll short around the switch since we run on full fan all the time and put the power cord on a surge protector with on/off switch. Access this electrical bus in the back of the insert by removing the 6 screws around the panel where the power enters the insert. In this picture, the third (3) bus is for the hot (black wire from power). It then goes off off to the rheostat and returns to bus (2). Bus (2) connects to both fans for their power. Bus (3) is the common for both fans.
8. The pic of the back of the fan shows that they can run on direct power (120v 60hz where I am) soooo I moved input power bladed connector from bus (3) to bus (2) where power returned from the rheostat. (see the little arrow in the picture) Now when I plug in the fans, they come up to maximum speed quickly.
9. Reverse the steps to put it all back together and I've just save $200 labor and close to $200 in parts! A lot of this looks obvious or I'm also trying to document in case I need to replace my fans some day!
Thanks for the pictures! I will be doing this mod before winter
