xraycer said:I've read that you want to have at least a few feet of vertical venting to create draft incase of power outages to prevent smoke from back-flowing into the house. Is there a magic number that works best, or is it the taller the better?
RKS130 said:Our Accentra FS was installed about 3 weeks ago by the dealer. The venting is horizontal, save a low degree of pitch between thge stove and the thimble. Should I be concerned about this?
Interestingly a friend I haven't seen in a while who has 5 pellet stoves between his two houses, alerted me to the vertical venting issue the same day this thread was started. The Harman book that came with the stove is clear that vertical is optimal, but the dealer still says not to worry. Now I am not so sure.
Obviously it would not be a big problem to rework the venting. Should I?
If I had any idea how to insert a photo here, I would.
smoke show said:soupy got lost again.
check your manual.
taller is better. IMO
xraycer said:smoke show said:soupy got lost again.
check your manual.
Manual doesn't give any recommendation on how tall the vert section should be. Lady on the phone from the town hall says that the inspector just goes by the manufacturers guidelines. I'll try to get in touch with the town's code inspector to see what he has to say.
SmokeyTheBear said:xraycer said:smoke show said:soupy got lost again.
check your manual.
I beg to differ page 10 if this is a free standing stove.
smoke show said:SmokeyTheBear said:xraycer said:smoke show said:soupy got lost again.
check your manual.
good call smokey.
25-EP manual http://englanderstoves.com/manuals/25-EP_EPI.pdf
check your manual.
