Wall behind Pellet Stove. HardiBacker or Durock
PelletNJUSA
14
USA
Hi all,
Behind pellet stove had sheetrock with brick vaneer. I needed to remove the wall, now rebuilding. Forgive me when I sound ignorant (Because I am, haha) but the choice of wall is either Hardi backerboard or Durock Cement Board. The question I have is, which is easier to work with and less messy. Also, can I put brick veneer on both if I take that route ? Also, are both considered to be fireproof. Behind this wall will be 2x4 studs, then 1 foot of space, then the block wall, then the exterior Masonry Chimney. In between is a thimble. Of course the install will be to manufacturer specifications on clearances but in general are both products considered fireproof and to code. I will be selling the house. The next homeowner may go with a different type of stove. I just want to be sure the wall at least works not matter what appliance is there. This is in the basement. Thank you.
Drywall is all that's needed for my installation as long as you maintain or exceed the minimum distance stated in the manual.
They will preform the same. How hot do you think your stove will get? I can put my hand anywhere on my stove except the door without getting burned.
Just as an aside, Durock is the Russian word for stupid.
