Warming the flue
Spaceman
12
Vancouver
I have a Supreme Lumis 22 wood burning insert. It works great, but I find that I do need to warm the flue or I can get smoke coming into the room. After the flue warms, all good. So wondering what is the most efficient way to warm the flue without creating smoke doing it. I have used a propane torch, but wonder if anyone feels there is a better method, or maybe that's the best. It has a baffle at the front, but it also has a clean out cap inside the box which leads directly to the liner, so I figure it's better to open that and warm directly there. Anyway, just wanted to see if anyone has any views about doing it.
Also, do you find that warming the flue is more or less necessary when it is colder outside. I live in Vancouver, so it's only about 10 degrees C right now. Winter does not get as cold as out east.
[Hearth.com] Warming the flue
I have a camp up in Maine where it gets quite cold. On a cold start when we first get up there, I do my best to split some very small kindling and do a “top-down” fire to minimize smoke coming into room. But yes, a cold flue will cause smoke to come back on you for a short time. Once we have been there and keep the stove going, no issues.
10 defrees celsius is mild so your draft is going to be weaker at the moment.
I've always just held a flaming piece or two of newspaper up near the flue, once the draft is established there will be a whoop noise and the flame gets sucked up letting you know your draft is good to go.
Interesting that you say the startup draw is worse when it's not as cold outside. I would have thought that being colder out would mean a colder air plug, but I guess it's about the difference between outside and inside temperature.
I used to do exactly that when I had an open fireplace because I could hold the newspaper right up into the flue, but now that I have an insert with a baffle, I find that if I hold it at the baffle, because it's at the front, it invariably results in smoke in the room. Because my particular insert has that cap at the back, as pictured, I use that, but then I found it neater to use a small propane tank with a nozzle. Do you burn paper at the front or does your insert have a direct opening to the flue?
Towards the back of the stove there is an area that will catch the flame and suck it up over the baffle.
I second the Top Down fire set up for numerous reasons.
So in your insert you hold the burning paper at the back even though the baffle is at the front, or do you mean that your baffle has an opening at the back? Mine is at the front, as pictured.
I don't have a smoking problem with the masonry chimney in the middle of my house, but
the top down creates much less smoke at startup,
it's heating the top of the stove immediately,
you can usually close the door right away after lighting,
You don't need to open the door until you are ready for a complete reload.
But i do have a slight smoke spill with my short chimney in uath.
I don't prewarm, just do a good top down set up with lighting it as far back as i can.
I'll get a puff of smoke sometimes but then it draws quickly enough.
In this case i sometimes opt for an egg carton with small dry twigs and a bit of canola or other oil drizzled on the cardboard egg carton. this speeds up the initial startup.
I think this depends a lot on the exact stove or insert design, the pressure situation in the home, the temperature in the pipe vs in the home etc.
I don't think there's a general ideal way to do it.
Draft is a function of the difference in temperature in the room and outside. If it's warm outside, that difference is less, so draft is less - until the flue is warmed up by the fire, because at that point (being e.g. 400 F), the fact that it's 45 F outside rather than 35 F, doesn't make much difference anymore.
A cold column of air in the flue indeed can sink down once the stove door is opened, and flow out. That's a tough situation. More often happening for external chimneys (rather than ones going up inside the insulated envelope).
Low pressure in the stove room can make it appear as if there's a reversed draft; then the home just uses the connection to the outside through the stove to equilibrate the pressure in the room with that of outside. This is more often the case for stoves in homes that have higher floors and particularly if those higher floors are leaky. (Or, of course, if there's an exhausting fan running, bath, kitchen, drier, boiler, etc.)
My experience is (with a basement stove, and external chimney, so some risk) that aiming my propane torch towards the flue (granted through a hole like your clean out) for 20-30 secs does help avoid smoke roll out upon start up.
So I do that always. Had my basement full of smoke (because I often start my stove completely loaded with many big splits, and some splitter trash on the top) two or three times. That's annoying. That has not happened when I use my torch, even if I open my stove initially and feel cold air rolling out while I load it.
So I load the stove, then finagle the torch above the load, to blow up the flue for 20-30 secs, and then use that same flame to start the fire.
That works for me. YMMV
My brick chimney is on the outside, so maybe that makes a bigger difference. I tried the top down without heating the flue and sometimes it works fine and sometimes I get smoke cascading in the firebox and coming out of the vents for about 1-2 minutes until it gets the draft going, but by then, there is a lot of smoke on the room, which is not good. So for me, safe bet is to warm the flue.
For sure those exterior chimneys can be a bit of a hassle to get your draft flowing.
Hair dryer
Propane torch.
Couple candles (slow)
clean burning fire starters.
in your case the propane torch may be your fastest and easiest option
Reactions: stoveliker
Thanks. That makes sense. It's pretty much exactly what I am doing, so I guess I am not alone in finding that this is ideal, so good to have that confirmed. Also appreciate all the other comments too, to give me more insights. Cheers everyone!
For stubborn chimneys, I have found that carefully using a hair dryer, or heat gun provides the most reliable results, by far.
The other methods can work, but spotty results IME...propane torch pointed up the flue isn't terrible either...but the hair dryer method provides heat, and positive pressure too.
I always wondered about putting a votive candle or two in the stove for some time before lighting the stove...maybe that slow more complete warming might do the trick too? Plus it can be done with the door closed, so no stinky smoke risk in the house (not that candles generally stink, but some of the other methods can!)
Reactions: Ctwoodtick
If you try the candle method, I’d suggest putting them on a bucket or log or something to lift them up so their flame tips just touch the baffle plate. With the goal of heating up the baffle metal much faster.
I do top down fire but still use a propane torch. I hold it there for a while and then light the fire with the torch. I was having issues with the draft catching. Even with the top down fire smoke was still building up in the stove. The stove would start drafting at some point but not without smoke coming out into the room. I can't have that so torch it is. This solved my problem.
Reactions: bigealta
The "cleanout" is a novel design. Normally, that would be a bypass to facilitate easy starting, but apparently not for this insert.
Reactions: moresnow
