Good God
Pleeze tell me I missed something here or maybe you did. I really hate to call you out on your extremely low pellet use figures to heat your house when the outside temps plunge because exaggerations can be very misleading .
Anyway, .78 lbs of pellets per hour isn`t much heat , maybe around 4-5K BTU after heat losses up the stack and I`ve not yet heard of a space heater running on low that could heat a house to 74 degrees when the outdoor temps went down to 13 degrees.
And all this on a 12 yr old pellet stove running on low?
That said ,I wish my kwhr rate was .09. I`d probably think about going back to electric heat.[/quote]
Gio,
The .78 lb/hour figure is based on last year's total burn. The stove was on (auger on) 1600 hours and I used 51 bags of pellets, you do the math. Being a manual stove, I record start and stop times on a spread sheet for each month to come up with the burn hours. I also read my electric meter to my sub-panel that only my baseboard heaters come out of at 7 am and 7 pm every day. These are also entered on a spread sheet, so I know how much electricity my baseboard heaters are using. My spread sheets are in Quatro pro if you are interested and I could send them to you if you would like.
I also have two weather stations. One gives me outdoor temperature and second floor temperature, while the other gives the temperature on the main floor, where the stove is and the temperature in my un-heated basement. I will try to post a graph of the last two days temperatures. My home was built in 1988 and each floor is about 700 sq. ft. and a very open floor plan.
Mark[/quote]
Thanks Mark , I hadn`t realized that you use your electric heaters 12 hrs during the day and that yours is a fairly small house . Still, it has to be super insulated to maintain those stated 73-74 temps for those colder 12 hrs at night. I do envy that $.09 kwhr price though. (Mine`s $.18 )
Regardless, you are still doing unbelievably good by keeping the house that warm for the other 12 hrs that are normally colder with the pellet stove running on low. I do know that you don`t get a whole lot of heat out of a pellet stove at .78 lbs per hour , especially living in the mountains in Colorado.
Now lets see , .78 lbs equate to a 51 hr long burn out of a bag. I could be wrong but I think that`s nearly unheard of with most pellet stoves. I think most stoves would die out at that rate not to mention a low efficiency rating .
The best I can do with my small Harman P-38 is 36 hrs from a bag at the lowest setting. Maybe I need to look into one of those old units like you have.
